I ran random cheap dex in both GM cars I ever had(both Saginaw pumps), over 2 years in my 96 Sunfire, I once even go bored and dumped a few ounces of STP in it to see if the pump would quiet down at all, no changes were noted. The 98 Bonneville blew a motor right after I broke the pump and installed a reman one full of supertech dex 3 HM. Never a problem, didn't whine any worse than it did on anything else.
My father only ever used dex 3 in his GM pickups with saginaw pumps. Again, no issue.
Power steering fluid doesn't need to do much but deal with heat(hence the M1 recommendation)and be good at being hydraulic fluid. Most cars are running on some black watery fluid that was once cheap trans fluid, PS fluid, or some combination, anything fresh is better than that, you could probably run a Saginaw pump on 5w30 motor oil and it wouldn't complain.
Though not really a GM product, I just flushed my 99 Prizm, which at least in Toyota trim, calls for ATF, with M1 ATF, I hope to never need to touch it again.
