2005 Honda Civic 1.7L with Auto transmission.
This car used to be my moms and was serviced by the books at the dealer. Now the car belongs to my sister, and I do the maintenance. I keep up with oil changes, and at the next change (which is soon) I told her I'd do a drain and fill of the transmission.
She currently is away from home and has the manual in the glove box. What kind of fluid does this car take and how much does it require? I assume there is a drain bolt on the pan.
Also, what is the procedure for checking the fluid? On my Cherokee I check the fluid at operating temp, in park with it idling, after shifting through each gear selection. This is according to my shop manual.
Thanks!
Thanks!
