What's a clean freak to do? Over the past 20k miles on my saab (I got it used in November) I have used the following to "desludge" it.
-1 chemtool flush
-2 courses of arx
-2 changes w/ HDEO
-Redline
-LC20
-Neutra
Now, I have lots of dirty filters and the largest measureable cosmetic change (I have LOTS of photos under the valve cover) was with arx. However, even with arx I still have lots of deposits. My con rod and main bearing caps were still coated with sludge when I removed my oilpan to clean out my pickup screen though. Currently I have Redline in which I spiked w/ LC after about 1000 miles and then, about 600 miles ago added a course of Neutra. Yet, even under the valve cover there are still the same spots where I can take a finger and scoop up little clumps of sludge. They just look like they've been hanging out, completely unaffected...I don't want to keep risking Neutra every change if it does indeed swell seals a bit (according to Bob's tests, it did) and I don't want to keep forking over $40-50 for arx...I guess since I HAVE 24 bottles of Neutra, though...
Depressing....
Frank, if you have a new top secret industrial formula you need a guinea pig for, I'm your man.
-1 chemtool flush
-2 courses of arx
-2 changes w/ HDEO
-Redline
-LC20
-Neutra
Depressing....
