M motoman358 Joined Nov 22, 2005 Messages 43 Location Milwaukee, WI May 15, 2006 #1 Ive heard of people using ATF as an engine cleanser, how would you guys rate it compared to auto rx? also, when using ATF, what is the procedure? would it be the same as auto rx (run for 1500 miles then do a 2000 mile flush)?
P psudaytona Joined Feb 16, 2006 Messages 936 Location Pittsburgh,PA May 15, 2006 #2 I dont trust ATF in an engine, I dont think it can compare to the lubrication abilities of any motor oil and I here it isnt an ashless burning oil. If you wanna clean out your engine, I would say go the Auto-RX route.
G GROUCHO MARX Joined Jul 24, 2002 Messages 11,408 Location The Sandhills of NewYorkistan May 15, 2006 #3 I wouldn't compare the two.
M mechtech Joined Aug 11, 2004 Messages 2,383 Location Chicago area May 16, 2006 #4 ATF is not an engine cleaner, although many have used it to try and achieve cleaning. It has dispersants, but little or no detergents.
