The guy that wrote that baloney has never turned a disc on a brake lathe! I have and I have seen the metal, not pad material being removed from the disc.
I see stuff like that read often and wonder who started that rumor? Sure sometimes pad material on the rotor does ocasionally happen but 99% of the rotors I have turned were warped or had thickness variation in the metal and not pad material stuck to the rotor.[/quot
I agree with you. Rotors do warp, in fact there is a spec for rotor run out that has to be measured with a dial caliper. Even though the rotor thickness can remain constant around the rotor, run out is another thing altogether. I would dismiss this article as in error.
