Originally Posted By: CapriRacer
It's obvious Dr. Topp is talking about pure snow traction - that is the affect tire wide has on in their traction testing - which is done in groomed snow where the tire is not allowed to touch the underlying surface. What he is saying, in essence, is that having more of the biting tread surface in contact with the snow is better. Perfect sense.
What he is NOT saying is about what happens if you can get down to the road surface - and the fact that narrow tires are more likely to get down to that road surface.
I know the article is trying to be helpful, but sometimes these technical types get wrapped up about a particular slice of the bologna (or is that baloney?) and forget the bigger picture.
Continental is not backing away from the "wider is better" mantra, at least for their line of performance winters. They have a web page dedicated to it:
http://www.continental-tires.com/www/tir...wide_tires.html
"It is a common misbelief that you shouldn’t use wide tires in winter. However, that is outdated. In fact, they offer a variety of benefits:
>the wider the tire, the better the performance in all wintry conditions
>more sipes that interlock with the ground, even on snow
>shorter braking distance due to larger tread blocks
>consistent and balanced drivability and better steering precision
>sportier driving comfort..........."
