I just had my water pump replaced and the shop filled the overflow reservoir up to about a half inch from the base of the rim. The MAX line is about halfway up the entire reservoir, so there's a good bit extra in there. It's not COMPLETELY full, but very close. They either didn't bother to look for the MAX line (you have to really look for it to see it) or they just knew it could take it and not have an issue. This shop really knows Hondas so I'm not sure what to do. I'd like to be better safe than sorry and buy a $1 turkey baster and take a bunch out, but what do you think? Is it OK to leave in? What are the risks?
BTW, it's a Gates pump and a Gates belt that was used. They said Honda only sells pump and pulley together, and I had my old pulley since it snapped off the (bad) pump. Saved me some $$$ they said. I think I'd rather it anyway since Honda's water pump quality apparently is less than stellar.
