Submitted this oil sample right at a year hoping that I could squeeze 25K out of this fill. Based on the results now I'm wondering if I shouldn't be extending this longer? I will probably still replace the Amsoil oil filter at 25K, if not oil & filter.
Make/Model: Isuzu 6.6 Duramax LLY
Vehicle: 2004 Chevy 2500HD
Code:
OIL AME 15w40 AME 15w40 AME 15w40 AME 15w40 VPBE 5w40 VPBE 5w40
MILES IN USE 21,779 19,779 12,006 9,006 8,038 6,000
MILES ON UNIT 145,003 123,224 115,451 112,451 102,862 100,824
SAMPLE TAKEN 6/13/13 6/13/12 3/1/12 1/2/12 9/6/11 8/26/11
MAKE UP OIL 2.5 2.5 0 0 0 0
IRON 14 16 11 9 7 6
CHROMIUM 0 1 0 0 0 0
NICKEL 0 1 0 1 0 0
ALUMINUM 2 2 2 2 2 1
COPPER 3 4 2 2 3 2
LEAD 2 2 1 2 6 1
TIN 0 1 0 2 0 0
CADMIUM 0
SILVER 0 0 0 0 0 0
VANADIUM 0
SILICON 9 8 7 7 8 7
SODIUM 5 6 5 5 6 7
POTASSIUM 4 4 0 0 0 0
TITANIUM 0 0 0 0 0 0
MOLYBDENUM 0 6 7 8 42 43
ANTIMONY 0
MANGANESE 0 0 0 0 0 0
LITHIUM 0
BORON 2 10 9 10 34 40
MAGNESIUM 31 197 213 234 1190 1319
CALCIUM 3888 3604 3153 3334 820 849
BARIUM 0 0 0 0 0 0
PHOSPHORUS 1252 1262 1132 1241 1071 1191
ZINC 1500 1323 1226 1369 1300 1417
Fuel %
Soot
Insolubles % 0.3 0.2 0.2 0.1 0.2
Water %
SUS @ 210F 74.6 73.0 71.3 71.7 71.9
Visc @ 100C 14.6 14.14 13.73 13.29 13.40 13.44
TBN 7.0 5.8 8.7
Oxidation 53
Nitration 10
Flashpoint 430 425 435 400 420
Antifreeze % 0.0 0.0 0.0 0.0 0.0
Oil Analysis Vendor Comments:
Flagged data (Magnesium) does not indicate an immediate need for maintenance action. Continue to observe the trend and monitor equipment and fluid conditions. Magnesium is slightly high for this lubricant. Oil is suitable for continued use. Observe for trends in future tests.
Keep in mind this was the first sample done through OAI, all previous submissions were done with Blackstone.
Code:
IRON 14 16 11 9 7 6
NICKEL 0 1 0 1 0 0
COPPER 3 4 2 2 3 2
LEAD 2 2 1 2 6 1
TIN 0 1 0 2 0 0
CADMIUM 0
SILVER 0 0 0 0 0 0
VANADIUM 0
SILICON 9 8 7 7 8 7
SODIUM 5 6 5 5 6 7
ANTIMONY 0
LITHIUM 0
BARIUM 0 0 0 0 0 0
Fuel %
Soot
Water %
TBN 7.0 5.8 8.7
Oxidation 53
Nitration 10
