Technically shock dosage shouldn't be necessary, but it would speed up the chemical mixture ratio of FP:Gasoline.
If the effective dose is 1oz per 5gallons, then on a 20 gallon tank you should shock it with 4oz. Then each time you fill up, depending on how much fuel you add, you add corresponding amounts of FP to keep the concentration roughly the same.
