On the wifey's '96 Camry V-6, pre-sludger, I'm approaching the drain of the second rinse phase.
I've not done any prior analysis on this engine.
Though I've been here a year and learning all the time I've no clue if there is any value to be gained from having this oil run.
On the one hand I guess that the results are heavily skewed for obvious reasons.
On the other hand I've no clue if there is anything that might be learned
I would sure appreciate some input from those of you that know. I don't mind the cost at all if there is a possibility that there might be some value to doing it. If it is just plain useless, well...
TIA, John
TIA, John
