UPDATE: 28 miles in and sone hours of use later, I am noticing more improvement.
Not dismissing need for trabs drop, but, this is promising.
Use and heat appear to be key. Its getting stronger.
Like Rocky Balboa!
Originally Posted By: GreeCguy
Originally Posted By: TechnoLoGs
It is making a very, very small difference, this Seafoam product.
I have to tell myself to leave it, and do water pump first.
And I had that syphon once. I hope the hose is long enough!!
I also have empty gallon so you can see how dirty it was.
Originally Posted By: surfstar
Add some BG and Lucas to it while your at it. Maybe once .1/2 the ATF is trans additives it will be 'fixed' [as in fixed in gear again].
Settle down. A little knowledge can be dangerous - A little 'maintenance' can also be, as we've seen.
I tried two bottles of Lucas on mine but it didn't do a thing, (added one bottle, drove for a while with no improvement, read the bottle which said "might take two bottles" so added another - no improvement).
I will admit the mistake I made was throwing a lot of additives at mine in a short time because I was desperate for a fix. If I had it to do over again, I would change fluid and filter like I did mine before and then add the Seafoam. After adding the Seafoam in the Advanced Auto parking lot, I went from "I hope I make it home" to "I can't believe how well this is working."
Remember to look for the Seafoam with the RED CAP as both bottles/cans look almost the same.
Once you add the Seafoam trans fix, leave it in for a while. If you add it and start pulling the fluid out, you're removing the Seafoam as well.
