hi. i have an empty bottle with fitting used by a chevy dealer to clean the fuel injectors on GM vehicles. apparently you disconnect the power to the fuel pump, hook this up to the test valve on the fuel rail and run the vehicle on the contents of the bottle. i was thinking about using laquer thinner in a bottle and using the fitting from it to clean the injectors on my old achieva. will i do any harm to anything?
