I fixed another Briggs Quantum this weekend for a co-worker. It wouldn't start...but would cough and sputter like it was trying to. Classic symptom of a failed auto choke. Sure enough, the auto choke was stuck open. I had to remove the muffler and work it free, and used a little bit of spray lube to really free it up. I figure it'll work fine for another year, and then I'll see it again. This is on a 2010 Toro Recycler.
There has to be a better way than this. Seems the "Guaranteed To Start" warranty is for 1-3 years, and that's about as long as these silly auto chokes last before they bind up. Has anyone had better luck with these? Is there a trick or magic lubricant one can apply that will keep them working for longer than a few years at a time?
I don't like Honda's auto choke either, but at least with that one, you can bend a tab out of the way, which essentially coverts it into a manual choke (which I have done on my own GCV160). The Briggs requires partial disassembly (and additional parts, if there's a way to convert this into a manual choke.
