You won't find many fans of Lucas motor oils here. The oil analyses I've seen are pretty poor, especially for a "boutique" oil. I'd pick Redline, Amsoil, Royal Purple, Joe Gibbs, Roush, or an HDEO (Rotella, Delvac, Delo, etc.) before Lucas personally. The volatility was through the roof on a Lucas sample that PQIA analyzed, for example.
Congrats on the 440, by the way- as you can tell by my sig I bleed little Pentastar-shaped blood cells. Two running 440s, two more in pieces, a nest of Torqueflites, two 383s (one complete, one shortblock) and a whole lot of little bits and pieces as well as a few Mopars not currently roadworthy are gradually sinking my workshop into the earth.
IMO, the deciding factor for oil in a big-block Mopar comes down to:
1) what cam lift and valve spring pressures are you running?
2) what oil pump (std or high-volume and you better tell me you have a hardened oil pump drive shaft either way!)
3) Bearing clearances.
If you're running a cam like a 60s stocker Mganum/TNT/Commando cam, then you'll be fine with over-the-counter oil after initial breakin. Use a good break-in oil like Joe Gibbs Racing break-in oil just to be safe.
The oil pump volume and bearing clearances determine the viscosity. I prefer not to run anything over a 40-weight in mine, and anything with around 1000 PPM of ZDDP is fine for a broken-in stocker or slightly wilder cam. Diesel engine oils in 5w40 or 10w30 grade qualify, as does Mobil 1 0w40, but NOT Pennzoil Ultra 0w40- its designed for the roller-cam SRT engines.
Only go with a heavier oil if you've got a pretty radical cam and plenty of bearing clearance.
Welcome aboard!!
