I'm not a Millers Rep. I'm the NA distributor. As such, I really don't have time to sit and argue all day. Unfortunately there seem to be more folks interested in knocking innovation than learning about it.
ALL HTHS values are published minimums. I've posted links to the listed HTHS values and referenced those links many times. IN those links, you will find that EVERY HTHS value is listed as ">value." I did not respond to the "question" earlier because I suspected it was not a "question." Would I like them to be higher? Ceteris paribus, yes. But if you've actually read my other posts, you'd know I talk about the tradeoffs that come with it.
I have espoused the virtues of using high quality base stocks over VI improvers to achieve properties due to their stability. I won't even mention Millers, this is one of our dealer's* sites showing how inferior base stocks do not hold up:
Gibbs vs Mobil 1 break down I remain unimpressed with oils that use VI improvers to obtain certain characteristics, because as this test shows, they cannot maintain them.
So again, would I prefer a higher HTHS? Ceteris paribus, yes. But I'd rather have it start out low and stay where it is than degrade by nearly 30% and end up lower.
* - LN Engineering began carrying the gear oils before NT was in the engine oil, and are currently tied into their current offerings to a point where adding another brand isn't feasible.
Interesting to see how opinions have changed over time, having found some posts from some here saying the exact opposite of what they are saying now. I've had people tell me my oil is junk because of all sorts of reasons. They want twice as much ZDDP as is ideal and refuse to accept that 2200ppm of the stuff may build up. They want a "pure ester" base stock oil, and refuse to listen to anyone tell them that there is no such thing, that ester content tops out at about 20%. They want the highest VI oil they can get, darn the torpedoes on how it is attained.
The race teams we actually talk to look at the oil film, reduction in coefficient of friction, wear tests, load tests, etc. rather than all the stuff here. Oh, and dyno results that show power gains always help, too. I'm sure they are familiar with it, but the point is that they don't dwell on a single thing the way some folks here do. The team running the fastest Honda at the upcoming Indy 500 so happens to be one of those teams. They are using the full range of Millers oils in some of their development cars (Lights, F1600, F2000), but have not switched over the engine oil to the Indycar, yet (using Millers' gear oil, damper oil, and brake fluid). It is not a sponsorship, it is a technical partnership.
To date, some folks have been able to achieve better protection with a lower viscosity oil because of the nanotechnology. It enables protection in boundary lubrication that far exceeds that of non-NT oils, meaning the price for losing hydrodynamic lubrication is not nearly as severe as it is for just about anything else out there. We are working with Millers to do a full project on this, where we may reconsider the viscosity recommendation.
At the end of the day, some companies are going to let their marketing dictate the oil content, rather than engineering. Millers is a small company that has very little marketing budget, and one of the four highest ranking people there is the director of technology, who is the lead chemist, and is personally involved with development. That kind of behavior is how you get recognized by engineering publications like Race Tech Magazine, Racecar Engineering, SAE, etc. We've got several of those articles linked on our website, too, but it doesn't appear my providing links does much good.
