Quote:
Quote:
You talking to me? LC didn't do much. Neither did Neutra, really. I did 2 arx runs early on. Got some dirty filters, dirtier than any since. I may see if I can go that route again.
Nah, I wasn't going to risk missing a chunk and have it fall off to clog my freshly cleaned oil pickup screen. It's a REALLY FINE mesh.
Couldn't that just be manually cleaned out by spraying a solvent down there and using a little elbow grease, you have things opened up it seems that you could do it. Things don't look bad on the top end, just the bottom end. If you clean out the bottom end it seems possible that the rest of the engine would be fine. ...And then using Auto-rx if you still felt like it, you should have everything else taken care of, but it seems that if the bottom end was manually cleaned then there would be no need for that. What oil have you been running with the LC and Neutra?
