got a gallon, how much to add to a 4 quart sump to clean out sludge etc? bottle says 1 ounce per quart, just wondering what amount you guys reccomend, thanks.
also on a side note (instead of making a new thread) does anyone know of a good (maybe solvent based) cleaner for a cooling system? like a flush.... to remove as many deposits and buildup as possible for a more efficient cooling system.... thanks.
edit: hmmm thinking maybe water mixed 50/50 with that CLR (calcium lime rust) cleaner in the radiator and running it for about 10 mins at operating temp then draining would work.
[ February 28, 2006, 03:39 PM: Message edited by: Pontius Pilate ]
