Hey guys,
I am looking for a strong, permanent double-sided foam tape for plastic and glass surfaces that can withstand the interior temperatures of a vehicle.
The first application in question, is the mounting of my remote starter's bypass unit (smooth plastic box, weighs several ounces) to another smooth plastic surface (body ECU box). I have tried 3M's 10lb mounting tape from Home Depot with no success; the stuff simply doesn't stick well to smooth plastic surfaces.
The second application in question, is the mounting of my remote starter's antenna to the windshield. It is currently mounted using the included double-sided adhesive tape, but I would like to move it to a different spot.
My searches so far have returned 3M VHB (very high bond) tape:
http://solutions.3m.com/wps/portal/3M/en...C31gv)&rt=d
Does anyone have any ideas? Getting pretty frustrated at this point since I cannot use a mechanical attachment due to the location (no wire ties possible), and velcro doesn't seem to work either.
Thanks.
Thanks.
