Originally Posted By: KrisZ
Originally Posted By: TallPaul
I find that if you change the fuel filter every 10,000 miles the old ones have a fair amount of resistance when you blow through them compared to new filters. I am for changing them frequently to avoid over working the fuel pump.
That's because the filter media is wet in one and dry in the other one, not because the one with 10k miles on is clogged.
Soak the new filter in fuel and then try blowing through it, I bet the resistance will be very similar to the old filter.
After the initial check, which blew all the free fuel out of the filter, it sat for about a month or more, then I tried blowing through it again and it was still very difficult to blow through.
