Lately with the warmer weather I noticed the electric radiator fans (Rav-4) been coming on sitting at lights way more often than normal. Fluid level fine & thermostat replaced about 6 month ago.
Today I looked at it and noticed so many bugs on the ac condenser (I drive through farm land to/from work a good bit), plus top & bottom of radiator, and was surprise how many was on the front of the radiator behind the condenser. So decided to do some cleaning.
Since I had a couple tall cans of window foam cleaner (given when I got the tint job... I use Stoners glass cleaner for the glass anyway), I decided to spray the radiator and condenser allowing layers of foam to work from top to bottom. Used up both cans. The front end was dripping like a rabied Rav.
Then using a nozzle I flushed from the engine side. There was so many bug pieces streaming down the driveway. After done, picked out a few small rock (or something hard) pieces from the condenser and exposed parts (top & bottom) of the radiator, and straightened out some battered fins. Amazing how much bug junk came out.
Driving in the warm temps today the fans didn't keep coming on at stops, so I'm satisfied of the difference short of pulling the radiator.
Now that I think of it, is there a better way short of pulling the radiator? I had figured the foam soak softened up the bugs making it easy to back flush those creatures out with water. Maybe there's something better? I used up my free cans of window cleaner.
Will be a taking day long drive trip (1-way) in a few days and this got me to thinking. I don't have any bugs-b-gone.
