Sil Glyde Question
I just used it on my Caliper Pins today.
So, I was wondering earlier, doesn't "Sil" stand for Silicone?
syl-glide is not dielectric grease, period.
If you want real dielectric grease, get some from reputable source instead (e.g. CRC, Permatex, etc.)
Q.
If your caliper pins are seated in rubber boots, then you've just used Sil-Glyde for what it was designed for.
Yes. Last time I looked at the MSDS, the "Sil" part was a polysiloxane compound, which is a form of silicone.
Having said all the above, some automakers specify lithium-soap based lubricants for this application, not silicone based. No idea what kind of car we're talking about here, but you may want to check on that.
If you investigate the AGS product line, their msds' are very vague and inconsistent regarding their product's chemical make up.
Check it out for yourself: http://www.agscompany.com/lubricants/automotive
The Sil Glyde product is mostly polyethelene glycol, castor oil, and just a bit of some type of silicone: 7-13% http://www.agscompany.com/images/stories...-%20English.pdf
Dimethyl Silicon polymer with silica.............The SIL might mean silica.
Contrast that with Permatex's dielectric grease, whose MSDS gives its contents as follows:
POLYDIMETHYLSILOXANE >70
MODIFIED SILICON DIOXIDE OXIRANE, METHYL-, POLYMER 0.5-5.0
So 7% to 13% silicone compounds for Sil-Glyde to about 80% for Permatex's dielectric. There's your difference.
The Sil-Glyde MSDS used to list polydimethylsiloxane (at around 7-13%); I wonder if that's just another name for "dimethyl silicone polymer with silica"?
Hey, all you chemists out there.
I'm quite certain that polydimethylsiloxane term ought to be separated somewhere, but where? Should it be polydimethyl siloxane? Poly dimethylsiloxane? Other?
