Earlier this week, I did a routine service on a TSX that included rotating the tires.
After rotating the tires and setting the tire pressure, I noticed that there would be a very noticeable vibration and wobble at speeds between 10-40 mph. The vibration/wobble goes away entirely at speeds about 40, and you only feel a slight rough ride at higher speeds.
Do note, that the vibration was not present prior to the tire rotation.
I have triple-checked the tightness of the lug nuts so I am fairly confident that is not the issue. When I took the tires off, I was not purposely inspecting the tires for signs of damage but I did not notice any obvious issues (i.e. bubbling, puncture, etc).
At first I suggested to the owner that the issue may be wheel balancing and advised her to take it back to Discount Tire. However, after some more thought, this seems more characteristic of a bad belt.
The tires are Yokohama YK520 on the RF, LR, RR and have about 50-60% remaining. The LF is a near-new YK580 that was recently installed.
Thoughts?
Thoughts?
