Originally Posted By: Mike Simmons
Is it that there truly is NO drain plug or is it that the mower manufacturers didn't stamp the deck housing with an access hole for the drain plug. I originally thought that the Tecumseh on my Lawn Boy didn't have a drain plug, but when I removed the engine from the deck, lo and behold Tecumseh did indeed provide a drain plug but Lawn Boy didn't provide an access hole thru the deck.... go figger.
Mike
Exactly.
My newer Snapper mower with a Briggs OHV has a drain plug, but it's a real chore to use the drain plug because of where it lands under the deck.
Tipping the mower on either side results is gas getting where you don't want it and hard starting afterwards, so the best bet is an oil change only after you've run it out of gas.
That, and it's got a stupid little oil filter that I thought was a neat idea at first, but is ridiculous for a push mower IMO.
