I have a GM 10 bolt in a '94 1500 extended cab. 350, automatic. Pulls a ~ 4000lb boat/trailer combo in the summer (california valley heat) including hill climbs where I might be WOT for a minute or more at a time. It also sees quite a bit of highway miles at California highway speeds (75+) but is an aerodynamic brick, so that also loads the rear axle.
With 95,000 miles on it, I got tired of the howl from the rear end (been there since I bought it at 60,000 miles, previous owners pulled a trailer that was probably too heavy for the truck). So I'm having the 10 bolt rebuilt - new R&P, new bearings, etc. The shop doing the work says the drive side of the R&P is wasted.
To get to the point, I'm looking for recommendations on diff gear lube to make the new R&P last. I like the idea of redline shockproof, but I'm not sure this is the correct application (year round use, not racecar). I need something that will withstand sustained heat (hours on the highway at 75+, pulling the boat up into the mountains, etc.) and protect the gears. I'm willing to sacrifice MPG to make the gears last longer, and I don't care if the oil is a bit pricy or special.
So, any recommendations beyond synthetic 75w90 GL-5? Maybe something like amsoil Severe Gear 75W-110? I have no brand allegiances (I run PP in my miata, german castrol from my personal stash in my camaro, and Rotella 5w40 in the truck) so anything is fair game.
