Originally Posted By: surfstar
These front rotors are notorious for warping, OEM, aftermarket, doesn't matter it seems.
Really? I've never heard that before and your 2005 VUE appears to use the same front rotors as our 2007.
When I put the ThermoQuiets on at 59,500, it was prompted by a combination of warped rotors (i.e. runout) and worn out pads. But the rotor thickness and overall condition was good enough that despite those who said I should replace them, I had them turned and everything is working perfectly.
