Just finished flushing my power steering pump on my 1993 Ford Taurus GL, 3.0 V-6 AXOD metric tranny 155,000 miles.
About a month ago, I flushed with fresh fluid and filled with "Lucas Power steering pump" oil. Like their tranny fix, this stuff is really thick. The ole gal never really liked it. Power steering would "shudder" on turns and "whine" while at idle.
Finally, today, I pumped all that out with my little hand pump, did several drains and fills using some old Dex III I had sitting on the shelf. I would drain about 8 oz at a time, drive around the neighborhood using the cul-de-sacs to do my full lock left, full lock right, come home, drain and fill another 8 oz and do the same thing. When I was sure the old Lucas was gone, I did a repeat with Valvoline Maxlife tranny fluid in power steering pump. Ended up with almost the whole quart in the system. No more shudder and very little pump noise.
Question - this maxlife has a very strong odor. Smells strong in the pump and smells strong in the bottle. Has anyone else noticed this strong odor? Is that normal? To me at least, it's much stronger than the old dex III/M.
