Folks,
Following are a couple of UOA's I have had run on my 2011 Ford F350 pickup (crew cab, single axle, short bed) with the 6.7L diesel engine. The first UOA was on the oil-change I had done at the dealer - the oil brand is unknown, but it was a 10/30. The next UOA was on my fill of Rotella T5. The driving for the latest UOA was fairly light duty - moderate towing, some heavy loads in the bed, but mostly running empty on the freeway or around town. Air and fuel filters were changed at 15K miles.
I wanted to check the accuracy of the OLM hence the TBN analysis - it had clicked to "change oil soon" status. There was still about 300 miles remaining before it would notify to "change oil immediately" when I changed the oil. The TBN shows there was a lot of life left so Ford's OLM appears to be set very conservative.
The added fuel in the sample may be due to a PCM re-flash Ford did on the truck. After the re-flash the re-generations to burn off the DPF jumped dramatically - every 70 to 100 miles. It's now back to a more normal interval of 150 to 200 miles so I expect the fuel content to drop substantially during this oil change interval.
Blackstone comments -- wear metals are improving but engine is still new so further progress is expected. Keep an eye on oil level as it appears to be adding fuel. TBN was fine so the OLM seems overly cautious.
Code:
OIL Dlr 10w30 Rot T5 10w30 UNV AVG
MILES IN USE 6.7k 7.3k N/A
MILES (Unit) 14.7k 22k N/A
SAMPLE TAKEN 3/29/12 10/05/12 N/A
ALUMINUM 26 20 12
CHROMIUM 1 1 2
IRON 38 35 32
COPPER 5 5 5
LEAD 0 0 1
TIN 0 0 1
MOLYBDENUM 8 2 28
NICKEL 1 1 1
MANGANESE 1 1 1
SILVER 0 0 1
TITANIUM 0 0 1
POTASSIUM 0 0 2
BORON 15 18 21
SILICON 5 6 8
SODIUM 3 8 7
CALCIUM 2050 2380 1788
MAGNESIUM 146 26 401
PHOSPHORUS 1031 1073 1020
ZINC 1237 1246 1163
BARIUM 0 0 1
INSOLUBLES % 0.4 0.4 < 0.6
WATER % 0 0 < 0.1
FLASHPOINT ºF 455 380 > 400
SUS VIS 210ºF 60.7 61.1 59-65
cSt @ 212ºF 10.41 10.52 9.9-11.9
FUEL % < .5 2.0 < 2.0
ANTIFREEZE % 0 0 0
TBN 3.9 > 1.0
Thanks - Charlie
Code:
ALUMINUM 26 20 12
CHROMIUM 1 1 2
IRON 38 35 32
COPPER 5 5 5
LEAD 0 0 1
TIN 0 0 1
MOLYBDENUM 8 2 28
NICKEL 1 1 1
MANGANESE 1 1 1
SILVER 0 0 1
TITANIUM 0 0 1
POTASSIUM 0 0 2
BORON 15 18 21
SILICON 5 6 8
SODIUM 3 8 7
ZINC 1237 1246 1163
BARIUM 0 0 1
WATER % 0 0 < 0.1
ANTIFREEZE % 0 0 0
TBN 3.9 > 1.0
Thanks - Charlie
