Originally Posted By: maketracks
IIRC, my POS Safari has a 4L60E. It also says that anything 1992 and later was a 4L60E as opposed to a 4L60, and that the E was dropped when everything went electrical anyways.
Actually 4L60 is the early models that were NON electronic. In 1994, 4L60E came along and was electronically controlled by the PCM. Then you also had 4L65E which was a great transmission..basically a factory corrected and beefed up 4L60E.
