Is it possible for an average DIY'er to replace the sunshell in these units? I've heard its a weak spot in the 4L60E and I'm planning to replace it as preventative maintenance. Probably looking at replacing the 2/4 band clutch also. I'm not planning to heavily overhaul the transmission but I'm wanting to not remove too many parts if possible (valve body, clutch plates, snap rings, etc.)
