Originally Posted By: cptbarkey
i knew this was a toyota question before even clicking to read the post haha.
i have two toyotas which both ASK for 0W20, but HISTORICALLY they have both been ASKED to use 5W30. if your engine is the same way (i'm fairly sure it is) then use 5W30 with confidence. As a matter of fact, i would like to hear from other people if 5W40, or 20W50 is even usable, and i'm fairly sure it is because often those are the only grades available in foreign countries.
Subaru and some others are the only brands i am aware of that REQUIRE 0W20 or your warranty is VOID. No doubt because of teeny weeniie tiny oil channels amongst the block, crank, piston, etc.
Mobil 1 recommends their 0w40 for the 2az-fe over in europe, even the newer ones. All other oil companies recommend 5w30 in other parts of the world though. Don't know why Mobil 1's is different.
