Originally Posted By: JHZR2
Again, in the big scheme of things, small change.
We have had a lot of experience with Asian radiators, and they have ALL been quite unreliable, this is across Toyota, Honda and Acura. Id want the right chemistry in there to be sure that optimal longevity is obtained. Over a 200k mile ownership, this could amount to an entire radiator in my experience.
My +250k miles '94 LS400 has original radiator, it has Prestone and Peak all-makes/all-models with tap water for more than 12 years with no problem. I changed these once: water pump, thermostat, upper hose and some heater hoses. I think the key is change the coolant often, like every 2-3 years, then you don't have much problems.
