Patman
Staff member
I have never changed the oil on my wife's 2006 Jetta before, and was wondering what do you 2.5 VW owners use to remove the oil filter housing? I bought a tool on e bay which supposedly was the right one, but after further research I found out I got the wrong one (and bought it a long time ago so it's too late to return it) The one I bought is a 74/76mm wrench but it has 15 flutes in it instead of 14. After finding this out I went into my stash of graphite oil filter removal wrenchs and found one that might just work as it has 14 flutes in it and looks to be the same size as the wrench I got from E Bay. It is a Flo tool number 5. Has anyone tried this wrench on their 2.5? Or what about simply using a strap type oil filter wrench, would this work here? Before I go driving the car up on ramps and removing the underbelly thingy, I just want to make sure I've got all the right tools I need
Any other good tips for doing an oil change on the 2.5? I won't be doing the oil change until the spring (waiting for both warmer weather and another sale on M1 0w40 first)
