Originally Posted By: Spazdog
Originally Posted By: The Critic
From what one individual said, you need to remove the oil filler tube:
"It's pretty straight forward. No special instructions required. You will probably need to remove the acoustic cover from the top of the engine.
To do this, first disconnect the plug from the EGR valve. Then loosen the oil cap completely, after the oil cap is fully loose, continue to turn the oil cap counter-clockwise to loosen the oil filler stem from the valve cover. Then just remove the oil filler stem and carefully pull up on the cover to disengage the two retainers on the cover from the metal studs on the engine. After removing the cover, temporarily replace the oil stem and filler cap to prevent any contaminants from falling into the engine. "
http://chevroletforum.com/forum/equinox-23/2006-equinox-plug-wires-change-48675/
I don't think that information is correct.
The oil cap is on the front cylinder bank. I don't remember it being integrated with the beauty shroud/acoustic cover
I remember looking at that engine compartment when one of my clients purchased a used Equinox to replace her 200,000+ mile smoking and leaking Mitsubishi Montero. For the life of me I cannot figure out how taking the filler tube off will help you access the 1-3-5 plugs.
They did not have the same cover for 05 as they did for 06. Not sure but I had to go under the car and feel around to see if I could find it. Too much of a PITA on jack and stands, had to bring it to the shop. Much easier with the lift. I am also having them replace 02sensor replaced as it is right there as well. Two birds.....
