Exhaust Flex Pipe--Why some have, others don't?
By Detroit
Out of the many vehicles I have owned, and the 5 currently in my driveway, only one came with an exhaust flex pipe. If the flex pipe is so important why don't all exhaust systems have one? What are the consequences of replacing a flex pipe with a straight piece of metal tubing? I think it all depends on how much give the hangers have.
Cavalier OHV transverse has the spring loaded flange with asbestos-ey donut. The springs suspciously remind me of valve springs that didn't make the but for 5000 compressions a second.
IMO a flexpipe is smoother inside.
Our Acura does have a flex pipe. The two sides of the exhaust from the V-6 come down to meet together at a y-pipe, then through a flex pipe, then to a third catalytic converter. The flex pipe absorbs fore-and-aft movements of the exhaust due to the engine rocking back and forth (transverse mounting).
Our Honda does not have a flex pipe. Fore-and-aft movements of the exhaust are taken up at the flange at the bottom of the exhaust manifold; there are two bolts (with springs) and it's sort of a "ball-and-socket" joint there. That joint has been problematic (with a TSB out to replace that donut gasket), and Honda changed the CR-V in 2010 to a design with a flex pipe.
Did you or do you still own the (rear wheel drive, BTW) Aerostar? I've owned 4 of them and they came with the flex pipe. People on some of the Aerostar forums always said that a solid pipe would never last, so I've always put a flex pipe in as a replacement.
My Accord has three spring/donut joints and one flex pipe. Plus two other joints that aren't flexible. I've never seen so many joints since college.
Yes, the '92 Aerostar RWD 3.0 is the one. I had the flex pipe replaced about three years ago and it rotted already, so I just had a straight pipe installed. We hardly ever drive it anymore, 500 miles in last 6 months, so not sure we will see the adverse effects if any.
I see what you did there.
the only cars i have had with aflex section were v6 engines that both front and rear pipes join into one exhaust.. a 4 cly did not have one .. a flex pipe i believe is used on a transverse mounted engine due to rubber engine mounts.. when the engine moves the exhaust has to go along
I can see where the transverse engine fwd cars need flex pipe, but maybe simpler to just exit the exhaust out the side by the front tire and skip the flex pipe.
I imagine a big reason for going to flex pipes is to reduce noise, vibration, and harshness (NVH) in vehicles. Lots of manufacturing money is spent to reduce NVH.
Originally Posted By: HerrStig
Transverse engines need them, RWD with "standard" mounting -- usually not.
This. Transverse engines rock fore and aft and generally have mounts that allow a lot of movement to absorb vibrations from smaller engines, which makes the engine movement at right angles with the major axis of the exhaust pipe as it passes under the car. Either a ball-joint ("donut") or flex pipe is generally needed to allow enough range of motion.
Longitudinal (the RIGHT way ;-) ) engines rotate left/right under different loads, so they just tend to twist the exhaust pipe on its major axis. The engine mounts are ususally stiffer since rear-drive engines tend to be bigger v6 and v8 engines that don't shake as much. Compliant mountings in the exhaust hangers can usually absorb that movement so no flex pipe or donut is needed in most cases.
And that money carries over into replacement parts too. The difference between OEM and aftermarket flex pipes for the Accord is like night and day. If the pipe on my car hadn't been damaged it would probably still be good today. The Bosal replacement lasted about a year and a half, and was replaced with an OEM part which I don't anticipate wearing out before the whole car goes to the boneyard.
^ Yeah I cheaped out and got an advance flexpipe that wasn't stainless like the OE saturn one. A year later it's rusty and creaks horribly when flexed-- I don't give it much more time.
Ironically, if I had bought a direct fit catalytic converter (that includes flexpipe and downpipe up to the manifold), it would (probably?) have come with a stainless flexpipe to meet the required 5 year warranty.
Coincidentally my whole exhaust hangs on these 3 inch long rubber hangers that let the whole system move an inch fore and aft. The flex lets the engine rotate but there's still this fore and aft to contend with.
It's not the most sophisticated engine in the world vibration wise and the soft mounts get on my nerves when I'm going through the gears and can feel it bouncing around up there.
Oh yeah, I forgot about those things, in addition to everything else I noted on my Accord exhaust I have eight of those rubber things too.
Like everything else Honda though, it works and works well. Sometimes seems weird compared to my Toyota but it gets the job done and never seems to fail (on its own).
