2001 VW 1.8T (Passat AUG) with 174k miles.
As you can see, lots of carbon buildup, and small dents from valve contact. What should I do here, scrub as much as I can off without letting debris get into the ring area and hope it doesn't scour the cylinder walls? The rings have already been soaking in oil and a little Seafoam. Also, should I try to grind smooth those little valve dents?
