Originally Posted By: KCJeep
Originally Posted By: ARCOgraphite
Just ran the LiquiMoly MoS2 in the honda and it almost killed the engine. Had to drain 40 bucks of fresh EDGE 0w20 wTi. No, NO and NO.
Also:
NO.
ARCO posted a peculiar story some time back that quickly went from "kinda sorta I think this happened" to "It's all MoS2's fault it totally clogged the filter and nearly killed my engine".
ARCO you claimed MoS2 completely clogged the filter, yet you never opened it or posted pics of it that I saw or heard of... pure speculation on your part till you pony up. You could have simply gotten a bad filter, without some investigation instead of speculation we will never know.
FYI I am standing by with a host of full OCI run filters used with a full application of MoS2 which I HAVE cut open, as well as some used before that without MoS2, I'll warn you now you won't be able to tell which ones are the Mos2 filters until I tell you.
Maybe you just need to get away from wimply little Hondas.
Sorry, to the OP I highly recommend you e-mail and ask LMoly before using multiple products at once, I have found them highly responsive and thoughtful in the past.
Using Moly with some of the top of the range full synthetics does seem to cause a problem as I've been looking through some UOA's that are showing very definite jumps in the insolubles. Some of the major brand full synthetics from Castrol, Mobil, Liqui Moly and Amsoil don't contain Moly and it is not included because of some type of adverse interaction with the dispersant additives.
I've not seen any UOA based evidence of Moly improving the performance of a major brand full synthetic, although it does seem to improve the performance of cheap supermarket oils.
