Originally Posted By: skyship
Originally Posted By: Benzadmiral
I'm looking at buying an '08 E320 Bluetec myself. The oil was changed by an MB dealer at 10K intervals. However, my long-time mechanic still clings to the idea of the 5K interval for a diesel engine, despite what Mercedes recommends. Is it possible that severe service -- a lot of idling in traffic, etc. -- could shorten the interval by half?
Contamination effects dino and synthetics in exactly the same way, so if you are spending too much time in traffic 5K makes sense to dump the oil which might be sufferering from fuel and carbon (Insolubles in UOA) contamination.
If you do lots of long trips, then 10K should be good unless you get the real big oil killer, anti freeze contamination from a head gasket issue, although fuel contamination from a bad injector is nearly as bad.
My commute and routine remain the same: About 9 miles to work one way, about half of it at highway speeds in the morning, a little more stop and go in the evening; a 25-mile interstate-speed round trip to the suburbs about 5-6 times a month. Normally I rack up a little less than 10K in a year. (I have a feeling that with a '08 Benz I'll do a little more "fun" driving!)
I plan to change the oil myself -- a first change in about 2 months, at 90K miles. So the group's suggestion would be to take a sample for Blackstone, perhaps at 5K-6K miles, and decide then whether to continue the 10K interval, or perhaps cut it to 7.5 or 8K?
