Was at the boss's house doing a 110k service on their 2004 Accord 2.4.
As part of the service, I replaced the serpentine belt with a new Bando belt.
At cold start-up, I heard some light belt squeal and saw the tensioner moving up and down about 1mm. The tensioner does swing smoothly and does not make any noise.
After the belt was removed, i grabbed the tensioner pulley and noticed that it had some play, side-to-side, if I tried to rock it back-and-forth.
Once the new belt was installed, the belt drive is silent and the tensioner no longer moves up and down excessively at idle.
Does the tensioner still need to be replaced? My thought was yes, since there is still some play on the idler pulley bearing, and perhaps the new belt (less stretched) is masking the problem for now.
