Y yucca Joined Apr 4, 2012 Messages 514 Location NM Dec 22, 2012 #1 This oil was doing really well for a while then I got this report back. Cat 3508 65 gallon sump Delo 400 LE bypass filtration
J jegs Joined Dec 17, 2012 Messages 117 Location NE Dec 22, 2012 #2 Injector O ring or fuel line feeding injector is leaking fuel.
dnewton3 Staff member Joined May 14, 2007 Messages 11,413 Location Indianapolis, IN Dec 23, 2012 #3 Yikes - talk about dilution! Didn't seem to affect the wear. But there is cause to get it out, and find the leak before wear is compromised.
Y yucca Thread starter Joined Apr 4, 2012 Messages 514 Location NM Dec 23, 2012 #4 The oil had 2582 hours on it. It won't take long to troubleshoot/repair the issue. It is just to bad the oil had to be dumped.
Brons2 Joined Sep 16, 2003 Messages 4,793 Location Austin, TX MSA Dec 26, 2012 #5 wear metals look fine. fix the problem and keep the oil in service, the excess fuel will burn off in normal usage once the problem is resolved.
