Originally Posted By: hounddog
First off the COPPER is in the CORE. NOT the TIP. The TIP is what fires and wears. Most ALL plugs are copper core. I installed Autolite Xp Fine Wire Irdiumns with COPPER CORE in my 2009 Dodge Hemi. Thought it was imagination . Better idle. Fuel mpg hit the highest I ever got right after install. Then I found others posting same results. So NOT my imagination! I did some SEARCHING and READING about FINE WIRE IRIDIUM. This type plug is thought highly of in the aviation industary. They go on about long life,better burn,less carbon buildup,less voltage to ignite and such. I have run them 10,000 miles. They are warrantied 5 years UNLIMITED miles! Just remember the COPPER is in the CORE and used by most all plug manufactures. It conducts
electricity better then other metals. BUT the TIP is what wears be it nickel or Platinum or Iridium. Nickel being the cheapest fastest wearing of them.
I changed the plugs in my hemi a few weeks ago. It looked as though the old ones were still the original equipment. The ground strap was eroded in the middle.
Anyways mileage didn't change much if at all. I used ngk platinums. I did notice,like you,easier starting. It felt like it caught quicker. I used platinums simply because of how much of a pain it is to do them on this truck.
I usually use copper because it gives me a chance to read them,see if there is any oil on the tips etc. they are real easy to do on the mustang.
