-The time on the oil is 17 months.
-The engine in my Caterham is a 2L 16V DOHC Cosworth/Vauxhall C20XE (GM of England}, 190 hp, twin dual venturi Weber 45DCOE carb's with no starting chokes.
-The spec' oil grade is 5W-50 but that's for all engines regardless of state of tune for this engine family that ranges from 165 hp to 250 hp.
-The oil also contained 2oz of Red Line Break-In additive to boost the Phos' level.
The engine has a hard life including track days and fast road work. The engine is started infrequently, months can go by in the winter without the car being started or driven. When it is started the car is always driven enough to bring oil temp's up to at least 75C usually 80C before shutting it down. Maximum street oil temp's are 85C and normal maximum oil temp's on the track is 95C with one session of hitting 105C when the oil was fresh (no time to remove the sump shroud at a track event).
I usually wait until the oil temp's have reached 70C before using max' rev's but not always since it can take 25 minutes to do so.
Since the engine is not equipped with starting chokes, the method for starting the engine cold is the rather primative priming with raw fuel. That envolves turning on the electric fuel pump and depressing the throttle to the floor, usually just once, to squirt fuel into the four intakes. It usually will fire right up after that and the throttle needs to be depressed a bit for 30 seconds or so before it will run cleanly. It will usually idle after that at a low rpm even though cold. That's one main advantages of running a high VI light 0W-20 oil, when I ran heavier oils, due to the higher oil drag, it could take 10 minutes of running time before the engine would idle; a major drag, pun intended.
In light of the starting procedure and the fact that it has carb's tuned on the rich side for power, there is no fuel in the UOA. I credit that to always bringing the oil up to at least moderate oil temp's evey time the engine is started. I think that is part of the reason for the still high 6 TBN.
On balance I'm pleased with the relatively low wear numbers although I do wonder if installing a pre-oiler to bring the oil pressure up prior to starting would reduce the 4 ppm of lead. If it's been more than a few days since the engine has been run there is a light rattle for a second on start-up that does bother me but I'm sure I'm just being overly anal.
I suspect I could have doubled the length of the oil change interval to 3 years or more.
