Originally Posted By: sparky123
I've been thinking of doing my own oil only changes @ 6 mo intervals. This way I don't have to remove the plastic shroud/cover beneth the engine nor have to remove the filter housing/filter. All I'd need to do is remove the oil drain plug (which is not a hex bolt) and add 6 quarts or so of oil. Bought the car in April so I'd change the oil in November and then have the shop do the next oil/filter change in April on the car's anniversity date. I don't see a problem as I drive less than 10k a yr. And yes, once a week the car does get driven more. I thinking 2 oil changes per yr. would be best. Then, I'd keep using Castrol Edge bought when they're on sale.
Castrol Edge is a real good oil and my German Volvo dealer uses it and they are real fussy. If the oil drain plug is difficult to access (I have to remove underbody covers to get at mine)then you can use an oil change pump, BUT only if the engine type allows direct access down the dipstick hole to the lowest part of the sump.
It's difficult to figure out how an engine and oil will respond to extreme service issues, like too much time at idle or off roading (Dust contamination), because a weekly blast down the highway could reduce the contamination levels to allow an annual or 10K mile service.
The proof of the pudding is in the eating, so two UOA's one at the 5K oil only change and another at the 10K full service would give you the real answer. If the TBN drops too far by 5K, the oil has significant fuel contamination or has sheared below a 30 grade then there is not much hope of leaving the oil for one year or 10K miles. The wear metals are of interest because if the rate of accumulation is lower when you extend the OCI to 10K (If possible from the initial fugures), for example the Iron content is less than double the 5K figure then the 10K OCI is better for the engine.
This forum is good for advice on UOA results, so if you do one at 5K (35 usd inc TBN with Blackstones), it will be possible to figure out if a 10K OCI is possible or not. If the figures are good then you will need to get one or two more UOA's done to confirm all is well for 10K mile OCI's.
Annual oil analysis is still a good idea even when you have decided on your final service schedule, as it will show headgasket leaks, injections system faults and air filtration failures before they cause serious damage. The results can sometimes help in terms of planning ahead in terms of what to do with an engine that is in the terminal phase, because it will show if the main bearings, rings or top end is failing, which should indicate if it is worth doing a top end only overhaul because the Lead and Cromium figures are still OK.
A good quality main block that has a good OCI procedure that is exposed to inner city conditions will often suffer an ultimate failure due to valve seating and valve guide issues. The main bearings will be good and the rings OK, so a recon head could give another few hundred thousand before the pistons et al give up in a big way. Unfortuntely with the latest engines, everything tends to fail at the same time, so top end overhauls are not such a good idea on some new engines.
Obviously I believe folks should buy one good car and keep it until main block or rust related failure, although the older pre DPF diesels are better in long term engine life terms.
