I know that GM no longer licenses Dexron III and recommends Dexron VI as a replacement but on my 4L60E in my 98 chevy truck, I'm leery about using Dexron VI since it's a full or partially synthetic depending on which brand you buy. I used Mobil 1 ATF fluid in this truck years ago when the truck was fairly new and the tranny always felt like it was slipping so I went back to a conventional ATF and the issue went away.
So what Dexron III do you recommend that is not a synthetic? Thanks
Wayne
Wayne
