anybody know where i can buy wurth sig 3000 grease?
and you can't say from mgcycle.com which is the only site that shows up selling it at $25 a tube via google.
anybody know what the specs of this grease are?
it's being used on the outer axle bearings of a dana 60, it has zerk fittings. want to try and use the same thing that it came built with, but if i can't get the grease easily or it's going to be expensive then i'll just pull the other axle and clean the grease off. if i do that what do you recommend? I'd prefer something i can pick up locally for less than $10/tube.
