Originally Posted By: Johnson615
Alemite would be my first choice. Ive used there pistol grip for years without any problems. Bought a 14.4v gun about 4 years ago without any problems other than I had to buy a new battery. They are top notch IMHO. Lincoln would be my second choice. They are a fine produce as well. We've had a air grease pump for 120lb keg for about 10 years without any problems as well.
Depending on how often you use your gun it might be worth buying a battery powered gun from either Alemite or Lincoln. Pricey but very conveniente.
+1
Alemite guns are very superior!! The A-500 is a really good lever operated gun. The A-525 is a really good pistol grip gun. If you want a gun for life then alemite is the way to go if you dont mind spending some money on them. They go for about $50-$60. I use an alemite almost on a daily basis, I have some guns that are ten years old and they work like day one. The A-500 is capable of 10,000 psi, so it you need pressure then thats the gun!
I tried the lincoln battery operated gun and wasnt impressed at all! The battery would be dead after about two tubes! The alemite battery operated guns are way better, you can get up to 10 tubes thru it with one battery.
