So I need an alignment after putting on new outer/inner tie rods drivers side. I also need the shop to crimp the washer because I couldn't reach it since the transmission was in the way. That involves just cutting the zip tie I have on the boot, push boot and crimp. I even had another zip tie of the same length in case they didn't.
Well, the shop won't crimp a washer unless they take the tie rods out completely, cost $70. Perturbed, I agreed and just told them okay, 35 ft/lb on the castle nut, 55 on the locknut, 46 ft/lb on the inner tie rod, just being paranoid about oem specs and not trying to tell the guy to do his job, just trying to help him out with numbers he might need to dig around for. They guy stops me and says inner tie rods only need to be screwed on hand tight, as if it were an oil filter. I would have went along and paid the $70 until he said that. Then an 'are you serious' sort of dialogue went on between us and I left with my car.
Am I nuts? All I know is that i'm going to need to lift my car as high as possible and crimp the darn thing myself, just have to get around the transmission somehow. I'll be back to the guy for the alignment though, it's close to my work.
