Originally Posted By: Vikas
On most of the Honda of 2000 era with rear drum, the self adjuster works only if you really slam while going in the reverse.
This is completely false. Honda drums adjust when you step on the brake pedal in EITHER direction.
The adjust-in-reverse type is a completely different kind of setup. Honda has never produced a vehicle with this setup.
