Please help select the best grease for ball joints
Baja Californa, Mexico
I have all new ball joints on my 02 tundra 4x4. I need to know what is the best grease and how often must I apply it. All 4 ball joints have grease fittings. I drive 20 mi. a week off road, and about 80 mi. hwy and city.
Thanks.
I was reading about this a couple of days ago. My understanding is that the viscosity of the base oil protects against shock loading. So, Valvoline Durablend has a ISO grade of 125 where Mobil 1 has 220. Mobil 1 is the better choice for shock loads.
The grease I bought was Chevron Ultra Duty EP with an ISO grade of 460. My local distributor was able to get me a case (10 tubes) for $40 or 4 cases for $110. I figured it was a good deal since I already had spent the $400 on suspension and steering components.
http://www.alexisoil.com/sites/default/files/chevron-ultra-duty-greases-ep-nlgi-0-1-2-pds_5.pdf
I use the Schaeffers 274 and have used greengrease when out of the Schaeffers. I find both of those to be excellent as well. I used Amsoil moly grease in the past for chassis lube, but that product has been replaced and I have not tried the newer stuff yet since very pleased with the Schaeffers for several years now.
Originally Posted By: Tempest
I like CAT Desert Gold for desert conditions.
[snip]
My current choice too.
5% MoS2 for excellent EP resistance and the thickener is a calcium sulfonate complex to resist water and rust better than probably any other soap base.
Originally Posted By: Fastr1
Amsoil polymeric #2
This is what mine are getting (as well as the tie rod ends) as soon as I change my wheels/tires over for the early arriving winter season.
I may even try their Polymeric Off-Road stuff in the late spring/summer.
Uhg... So many choices. Running Lucas Red Tacky right now and will likely replace with either Valvoline Ford blend, full synthetic or simply mobile1. Any way I'm going wrong with that plan?
