Cheap oil filter cutters?
by irv
04/25/18 11:02 AM
Ford 1.5 EcoBoost P2243
by dogememe
04/25/18 10:24 AM
Ethanol free gas
by CT8
04/25/18 09:40 AM
Husq 322L, how to convert to brush cutter?
by andyd
04/25/18 08:37 AM
Do you ever use a gear selection other than D?
by ZZman
04/25/18 08:00 AM
BITOG Detail and Wax - Top Picks
by gofast182
04/25/18 07:32 AM
Inherited gallons of Amsoil 40wt oils all cars 30w
by Rmay635703
04/25/18 06:47 AM
Oil Filter Recommendations for a 82 trans am
by GMguy84
04/25/18 05:24 AM
Teflon tape vs. paste
by dlundblad
04/25/18 04:13 AM
Shelf life of various fluids?
by Chris B.
04/25/18 03:56 AM
Shelf life of unopened/opened oil?
by Chris B.
04/25/18 03:49 AM
Is there a search or filter option?
by MellieK
04/25/18 01:32 AM
The Cuban Sandwich
by BlueOvalFitter
04/25/18 12:46 AM
Can't decide...but I need another pal
by Marco620
04/25/18 12:36 AM
We Will Remember Them.
by Silk
04/25/18 12:28 AM
Venezuela Arrests US Chevron Employees for Treason
by Nyogtha
04/24/18 11:19 PM
Classwork, Homework, and Exam
by Shannow
04/24/18 09:50 PM
Hydroflouric Acid as Aluminum cleaner,deoxidizer
by daves66nova
04/24/18 09:10 PM
I asked Valvoline about Seq IVA
by Carbon12
04/24/18 08:42 PM
Motor teardown?
by Sealbilly
04/24/18 08:09 PM
emod, Rmay635703, Rabbits, Poolcueti, Burrito97
64846 Registered Users
95 registered (Bambam, 69Torino, 28oz, aquariuscsm, 1JZ_E46, bdcardinal, 6 invisible), 1852 Guests and 41 Spiders online.
64846 Members
68 Forums
282314 Topics
Page 2 of 2 < 1 2
#2797803 - 11/09/12 02:47 PM Re: Valvoline NextGen 5w30 - 5,020 miles - 06 Scion tC [Re: SLCraig]
Artem Offline
Loc: Florida
Originally Posted By: SLCraig
Great looking report.
I've used Nextgen conventional as well in my car, and although this is not the same engine it makes me think my UOA would probably look similar. Nice.
I always thought that the 8th gen Civics needed a synthetic or a synthetic blend in order for the oil to handle 6-8k miles safely but based on these results, it definitely looks like it should be able to handle 7,500 mile OCIs if the service isn't SEVERE.
2014 Mazda 3 Hatch 2.0L & 6spd - Idemitsu 0w20 Synthetic @ $0.75 a quart.
#2797890 - 11/09/12 04:23 PM Re: Valvoline NextGen 5w30 - 5,020 miles - 06 Scion tC [Re: The Critic]
skyship Offline
Loc: Tettnang, Baden-Wurttemberg, G...
Originally Posted By: The Critic
So, it basically performed identical to Amsoil OE?
It sure looks that way and this conventional oil does not even have any Moly in it.
#2797901 - 11/09/12 04:42 PM Re: Valvoline NextGen 5w30 - 5,020 miles - 06 Scion tC [Re: skyship]
Artem Offline
Loc: Florida
and is 50% recycled oil! thumbsup grin2
#2797995 - 11/09/12 06:46 PM Re: Valvoline NextGen 5w30 - 5,020 miles - 06 Scion tC [Re: Artem]
ltslimjim Offline
Loc: WatUpDoc
Yeah, the overkill use of Amsoil wasn't necessarily needed. It's all about what you want to use. However, the synthetics still offer a value and some security/potential to outperform the conventional oils. However, on paper the '1' sample we have appears to do alright.
92 Civic Hatch (stolen frown RIP)
07 Honda Fit Sport (A/T) WELCOME thumbsup
#2798778 - 11/10/12 07:47 PM Re: Valvoline NextGen 5w30 - 5,020 miles - 06 Scion tC [Re: ltslimjim]
Artem Offline
Loc: Florida
Why overkill? I used OE to set a decent baseline following the factory recommended 5k OCIs. Then i proceeded to extend the OCIs by using higher quality lube from Amsoil's "Signature Series" line. Based on the results, i could probably keep going, adding makeup oil along the way up to 15k+.
Since i wasn't seeing the ROI from the expensive lube that was being burned at such a large volume, I'm looking into other alternatives, and that's where the Valvoline comes in.
Like i said, i have a ton of the stuff from all the FAR deals these past 3-4 months and figured that it was time to use up all that free oil. thumbsup
#2798809 - 11/10/12 08:21 PM Re: Valvoline NextGen 5w30 - 5,020 miles - 06 Scion tC [Re: Artem]
ltslimjim Offline
Loc: WatUpDoc
Yeah, overkill in the sense that doesn't revolve around money. However, it leaves you with more headroom for extreme service, whether you can use that higher quality or not in the lube itself isn't about money at all. They are all just different tools.
So, it's probably beyond what is needed from a pure baseline standpoint, but needs can be defined differently. Start throwing insurance in there, and Amsoil becomes more of the apt product.
#2800784 - 11/12/12 08:15 PM Re: Valvoline NextGen 5w30 - 5,020 miles - 06 Scion tC [Re: ltslimjim]
Artem Offline
Loc: Florida
I agree. At the time, i was really interested in Amsoil and that's why i was running it in all my cars. I used the OE as a baseline and then went to the SS Line in order to see how far i can go on the "good stuff".
I still use Amsoil exclusively in my transmissions (and many of the cars i service as well). It works perfectly, gives me smooth shifts @ all temps and longer service life, if needed, even though i still drain it when needed.
#4275404 - 12/15/16 11:07 AM Re: Valvoline NextGen 5w30 - 5,020 miles - 06 Scion tC [Re: Artem]
veryHeavy Offline
Loc: MN, CA
Originally Posted By: Artem
Oil filter:
TINY Mobil 1 (much smaller then the OEM filter)
Why did you go smaller? Is there some advantage to doing so?
#4281127 - 12/21/16 10:39 AM Re: Valvoline NextGen 5w30 - 5,020 miles - 06 Scion tC [Re: Artem]
Artem Offline
Loc: Florida
No advantage that I can think of. Mobil 1 simply makes the oil filter with a smaller canister then OEM. It's rated for 15k so that's all I needed to know.
#4281158 - 12/21/16 11:12 AM Re: Valvoline NextGen 5w30 - 5,020 miles - 06 Scion tC [Re: veryHeavy]
Gasbuggy Offline
Loc: PA
Oil filter:
This thread is from 2012
CTS-V+Recaros 5w30 Magnatec
Volvo P1800 5w30 Euro L
Land Rover Series 10w40 VWB
76' 300D Edge 0w40
02 Yukon 10w30 MaxLife
95 Accord - 386k. Mobil 2 RIP
#4281256 - 12/21/16 12:56 PM Re: Valvoline NextGen 5w30 - 5,020 miles - 06 Scion tC [Re: Artem]
Artem Offline
Loc: Florida
What does it matter? Someone asked a question. I answered.
#4281559 - 12/21/16 07:33 PM Re: Valvoline NextGen 5w30 - 5,020 miles - 06 Scion tC [Re: Artem]
FlyNavyP3 Offline
Loc: Jacksonville, FL
Artem,
What ever happened to the TC? Did you ever try extended runs in the NextGen? Did consumption continue to improve or decline as the engine aged?
Luke
#4281690 - 12/21/16 09:54 PM Re: Valvoline NextGen 5w30 - 5,020 miles - 06 Scion tC [Re: Artem]
Artem Offline
Loc: Florida
Sold the beater when we needed something bigger. The current Mazda 3 hatchback replaced it.
Consumption stayed the same. These motors just like oil.
A buddy of mine has an 07 Camry with the same 2.4L and his consumption got so bad that he took it to Toyota and after they did their little oil burning test, they offered to rebuild the engine under warranty (150k on the car) so he's waiting for the parts and will let me know how it goes. His started eating like a quart every 1,000 miles.
#4290029 - 12/31/16 08:48 PM Re: Valvoline NextGen 5w30 - 5,020 miles - 06 Scion tC [Re: Artem]
ThirdeYe Offline
Loc: Grand Rapids, MI
Mine is burning about a quart every 2,500 like clockwork, using 0W-20 or 5W-20.
07 Honda Accord - 598k - Valvoline 5W-20/Purolator Synthetic PSL14610
#4290084 - 12/31/16 10:39 PM Re: Valvoline NextGen 5w30 - 5,020 miles - 06 Scion tC [Re: Artem]
Artem Offline
Loc: Florida
Yep, not much you can do about it, unless you rebuild it but that's obviously not worth the hassle.
Most people don't keep up with oil levels and I imagine that a lot of these engines are suffering as a result and we'll see a ton on them at junk yards as they start wearing out due to low oil levels. Sad.
Page 2 of 2 < 1 2
