We knew that heat is the enemy of battery, if we can keep the battery cool in the hash engine compartment we may be able to extend the battery life a little longer.
I bought Reflectix Radiant Barrier in size 25' x 16" from Lowes few weeks ago with $10 off coupon, the final cost was $5.87 + tax.
I tried it today, I cut a 24" long piece then fold it in half to double the thickness, the final piece is 12" x 16".
In the Honda S2000 engine bay there is a metal insulation between the battery and engine, I place it between the battery and the metal insulation. I drove to WM and other places during lunch today, the total drive was about 25 miles in the 90+ heat.
When I came home I opened the hood to check how the Reflectix Heat Barrier work, I don't have infrared temperature gun I just use my hand to feel the temperature. The side facing the metal insulation/engine is very warm while the side facing the battery is very cool, the side of the battery is very cool too, while the top of the battery is a little warm.
This is just a test to see if/how the Reflectix Radiant Barrier works, I will cut it to correct size and wrap around the battery next week.
So far I use 2' out of 25' roll, so the cost is a little more than $1, I will keep that piece there and cut another piece to wrap around the battery, so the total cost is about $2.50-3.00.
